Re: Removing a venturi
Posted by sflem849 on June 09, 2010 at 20:06:48 from (69.197.84.192):
In Reply to: Removing a venturi posted by The tractor vet on June 09, 2010 at 15:04:22:
The tractor vet said: (quoted from post at 15:04:22 06/09/10) Some really good penetrating fluid and light tapping with a elf hammer . I use Zep penetrating fluid as i have found nothing that will match it . Just rebuilt the carb on my S/MTA and let me tell ya it was STUCK big time . Now my only problem is trying to decide on witch one i want to put in , do i want to go back to the stock one or do i want to go to the next one up or do i want to go all out and put the 1 1/8th one in it .
Use the big one :D
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
