Posted by Dean Olson on June 09, 2010 at 20:08:13 from (76.31.42.124):
In Reply to: Removing a venturi posted by Joe N-IL on June 09, 2010 at 13:54:11:
Use the appropriate size deep socket as a punch to drive it out from the top. You'll have to remove the throttle shaft and butterfly. Use the closed/square side of the socket against the venturi and tap against the open/hex side. It with come right out without damage.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
