Re: WD9 injection pump leak
Posted by Brad Motheral on June 09, 2010 at 20:23:07 from (96.63.36.141):
In Reply to: WD9 injection pump leak posted by Roger in Iowa on June 09, 2010 at 10:12:36:
common problem. unfortunately the pump has to be completely disassembled to get that seal out. throttle shaft is about the last thing to come out when you take the pump apart.
