Re: Removing a venturi
Posted by RustyFarmall on June 10, 2010 at 04:46:02 from (209.152.78.140):
In Reply to: Removing a venturi posted by Joe N-IL on June 09, 2010 at 13:54:11:
Use a torch and heat the area around the venturi. Get it good and hot, but do NOT heat the venturi itself. Spray PB blaster on it as it cools, walk away from it until it is completely cool, and you can take that venturi out with your bare hands. The use of a hammer or any other excessive force will only result in a broken and useless venturi.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
