Re: E/85 Fuel
Posted by Janicholson on June 10, 2010 at 10:13:09 from (199.17.6.76):
In Reply to: Re: E/85 Fuel posted by RustyFarmall on June 10, 2010 at 07:20:13:
Yes. The engines can produce the same HP if, (and only if) the compression is raised to 10.5:1 (not a fixed number, just very approximate based on a slow turning engine) The (effective) "octane" rating of alcohol is much higher and thus allows substantial increase in compression pressure. THis brings the engine into the same range of HP as gasoline (minus the increased consumption/HP/HR. Jim
