Re: E/85 Fuel
Posted by Larry B 1486 on June 10, 2010 at 19:50:24 from (67.142.161.30):
In Reply to: E/85 Fuel posted by S/C Bob on June 10, 2010 at 05:17:12:
I run E-85 in my old ford pickup truck. It's a 1994 model with a 460 V8. It's only used in a 40 mile radius as a service truck. Works fine in it. Run it for three years in it now with no problems. Can't really tell anything on gas mileage, four wheel drive at 12 mpg with gas or E-85. I started mixing it 50/50 at first then tryed it straight and could not tell any difference. Put a couple bottles of heat in it in the fall and spring to remove any water.
