The lower bushing (part 31 in diagram) should fit the upper bolster shaft with no more than .010" clearance (more like .005" is reasonable) I am not sure where you placed the shim. I am all for making things work, there is a possibility that the thrust bearing (#29)is no longer supporting the weight of the tractor. If the lower bushing is any longer (downward), or interferes with the thrust being transferred to the bearing (29) then it will steer much harder. Possible wear in can happen, but if greasy, it might take decades!!!. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
