Re: alternator update
Posted by Brownie 450 on June 11, 2010 at 05:52:50 from (66.43.241.95):
In Reply to: alternator update posted by karl f on June 10, 2010 at 23:05:08:
Run a jumper wire from the battery + terminal to the#2 terminal on the alternator & see if the alt. charges. This terminal reads battery voltage & has to be connected for the alt. to charge. # 16 wire is adequate for this.
