I'd like to see a copy of that "250 RPM" cut-in statement. That is pretty-much impossible. Might say "2500" RPM which is typical for a self-excite regulator. On a tractor with a 6" crank pulley and a 2.5" alternator pulley, the alternator would kick-in at 1100 engine RPM. 1200 RPM is about the minimum alternator RPM with a 3-wire setup. That's why those alternators are set-up to spin two to three times as fast as the engines when factory installed on cars. Typical Chevy engine idling at 800 RPM spins the Delco 10SI at 2000 RPM.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
