They shanged position of the cut-out when they went to a regulator and mounted below the gen so your SC would have came with a regulator mounted below the gen. You should get the generators Delco-Remy # on the block side so you can get the correct regulator if you need to replaceit as it is different from the generator that had the cut-out mounted on top of the gen.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
