Super H Float Needle
Posted by MJ in IA on June 12, 2010 at 07:34:37 from (208.126.67.45):
I have a '54 Super H I have been working on. It runs well except that when I take it off a load it dies like it ran out of gas. I was told this was probably a float problem.
I went to CIH and bought a new needle and seat. When I went to install it I saw that the old seat had a "50" stamped into it and the new one had a "40" stamped into it. The new needle seat looked bigger than the old one. Will the difference make my carb run different? Is there no difference?
Thanks for any input,
Mark.
