Re: Farmall Super C voltage regulater
Posted by CNKS on June 12, 2010 at 08:45:22 from (216.144.104.128):
In Reply to: Re: Farmall Super C voltage regulater posted by couv on June 11, 2010 at 19:11:29:
Jim can give you the details, but a voltage regulator actually regulates the voltage as needed. With a cutout the charging is either on or off. I think the cutout basically disappeared when the tractors went to distributers instead of magnetos, thus they won't be found on the late C's/Super A's--up--Unless they were mixed as you noted. The mag then became an option, but I don't believe the cutout was installed with the optional mag -- I can be corrected as usual.
