Re: 450
Posted by Janicholson on June 12, 2010 at 19:05:10 from (64.61.211.3):
In Reply to: 450 posted by wonder on June 12, 2010 at 11:25:58:
If it has a TA, the TA direct clutch, and the TA one way clutch may be toast. A rebuilt TA assembly is reasonable (shop Hi Capacity, Ag Parts and Allied for the best buy. If it has no TA, (TA delete, or a aftermarket eliminator shaft),the trans and final drive could be at fault. The brakes would slow everything forward of and including the differential. If the brakes will slow it, the pinions and or bull gears might be broken.
If the brakes make no difference, then there might be problems with the trans. I would make sure to try high gear as it is direct input to output shaft. If nothing, it is time to pull off the top of the trans. Jim
