Re: 585 loader hookup
Posted by Jimb2 on June 12, 2010 at 19:11:01 from (72.38.123.67):
In Reply to: 585 loader hookup posted by MikeinKy on June 12, 2010 at 14:56:28:
Hi you can spend many $$ at CaseIH and by a power
beyond plate for the end of the aux remote valves.
IF you never use the hydraulic remote outlets then
you can connect the IN side of the Joystick valve
body to one remote outlet and connect the OUT to
the other remote outlet and tie the remote outlet
lever back so the remote outlet is open. If
Joystick is working in wrong direction, just swap
the hydraulic pipes at the remote outlets.
If you require use of the remote outlets at same
time as loader then the cheap way to install
Joystick control valves is:
Removed the aux hydraulic return tube from the aux
control valves to the draft control module under
the seat. See tube at caseih.com parts for 585
hydraulics page 8-450 item 18 Tube assy Aux Valve
return.
After you decide your method of connecting the
Joystick valve then post again and I will supply
more detailed instructions.
JimB
