Posted by Wardner on June 12, 2010 at 21:24:36 from (4.154.236.124):
In Reply to: Re: 450 posted by wonder on June 12, 2010 at 19:11:11:
The shaft on the right is probably the one you are turning by hand. At the far end is a coupling. It may be stripped. That shaft rides inside the hollow shaft with the gear. That is the IPTO driving gear and shaft. If you are turning that and the IPTO lever is pulled back or floating between engaged and disengaged, it will turn by hand.
There is another shaft called the sun gear in the TA. It has splines that plug into the TA clutch. It could be stripped.
You need to look at some exploded drawings of the tractor. You may be able to diagnose the problem sitting at your desk. Goto the parts section of caseih.com for an on-line parts book.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
