What part is needed for the carb? Is it the VN or VNN British Zenith? One has an accelerator pump and one does not. Besides the overpriced kits, new throttle shafts and new floats are available from several places. Same carbs are used in England on many small cars.
In regard to engine oil, any off-road diesel oil will be fine, regardless if you've got the BC-144 gas engine or the BD-154 diesel. Requirements are no different than for any other 1960s-1970s tractor.
Front loaders on 3414s are usually rated as thus:
Lift capacity to full height is 2700 lbs. Lift capacity to half height is 3300 lbs. Breakout force at ground level is 4000 lbs.
Loader height fully raised at top of bucket is 12 feet, 8 1/2 inches.
Three point hithc will lift a max around 2600 lbs.
Loader and three-point use two different oil reservoirs. Both call for universal tractor fluid (combo trans and hydraulic).
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
