Re: Cub seals
Posted by george Willer on May 31, 2000 at 10:46:29 from (205.133.30.70):
In Reply to: Cub seals posted by Scott Hansen on May 31, 2000 at 09:14:46:
Scott,
The die-cast housing the seal goes into were made in two versions...early and late. The `1948 would have had the early one. The late one had a larger hole to accomodate the rubber coated seal. The early seal was plain metal on the outside. If you can get a later seal, have the housing bored as you mentioned and it will be better than new.
Post A Followup
: Re: Re: Cub seals
