Re: international 3414 with loader- couple questions
Posted by jay42782 on June 13, 2010 at 19:28:05 from (72.2.175.249):
In Reply to: international 3414 with loader- couple questions posted by jay42782 on June 12, 2010 at 20:20:39:
sorry for asking a few what might be dumb questions but i plan on changing all the fluids on this machine due to sitting for awhile.
for the oil change the filter looks different than most todays filters.is there a filter inside what appears to be a metal filter housing?and how many quarts?
what is the best way to remove all the hydraulic fluid and replace with new both loader and pto.and do i need to bleed the system?
also when i brought the tractor home there was nothing in the gas tank.does it need to be cleaned before running new gas through the system.i was told to use lead fuel only.is this also true?
what about rear end oil?how to check or replace if needed.
once again i apologize for these questions.i will be ordering a manual asap.
any tips and pointers to get all the fluids that can possibly be changed and the systems clean will be much appreciated.
thanks in advance!!
