Re: f-20 cooling fan assembly
Posted by Nebraska Kirk on June 13, 2010 at 20:08:57 from (207.91.4.154):
In Reply to: f-20 cooling fan assembly posted by Henryv11 on June 13, 2010 at 18:22:05:
B C Williams said: (quoted from post at 19:22:05 06/13/10) I own a 1936 f-20 with a flat belt fan assembly.I recently dissassembled the assembly to inspect the bearings and clean it up.Can anyone tell me how the shaft that holds the assembly is attached to the block? Can it be removed and is the water jacket behind it? B C Williams
That shaft is screwed into the block. I will have to confirm this, but I am pretty sure it is a blind hole.
