Re: 1929 McCormick Deering 10-20 stuck engine
Posted by OLDIRON29 on June 14, 2010 at 03:10:45 from (67.158.177.6):
In Reply to: 1929 McCormick Deering 10-20 stuck engine posted by Ct Hay Farmer on June 13, 2010 at 19:10:43:
CT hay, as kirk said is correct! I used a bottle jack and oak dowel and pushed my pistons and sleeves up and out of the block on a Regular. BUT!!! with the 10-20 and the bath tub frame I don't think this can be done. You may have to remove the motor from the frame. If you tape pistons and can not brake it loose than it will be a bigger job! oldiron29
