Re: H wont come up to full RPM.
Posted by RustyFarmall on June 14, 2010 at 04:46:29 from (209.152.78.140):
In Reply to: H wont come up to full RPM. posted by Fuller's Farmall on June 13, 2010 at 18:53:34:
The spring inside the governor is weak, or more likely, the holes that the spring hooks into are worn out and you"re getting a delayed response when the governor tries to compensate for a load. There are probably some other parts inside the governor that need some attention also.
