Re: Super c
Posted by mkirsch on June 14, 2010 at 05:34:54 from (64.80.108.56):
In Reply to: Super c posted by mike f from Tx on June 14, 2010 at 05:24:47:
Is there a problem? If so you did not describe any.
The tractor came from the factory negative ground. It has a very simple electrical system, which could easily be converted to positive or negative ground in a few minutes:
1. Swap the wires on the battery.
2. Swap the wires on the ammeter.
3. Polarize the generator.
Odds are it was not hooked up negative ground because it was "supposed" to be. More likely that someone who didn't know any better hooked it up negative ground because that's how everything is hooked up these days.
8 Volt battery indicates that the previous owner was having problems with the starter. It's a band-aid for a sucking chest wound. Odds are that simply cleaning the battery cable ends, or replacing the battery cables would have fixed the problem with a stock 6 Volt battery. A Super C does not turn over hard, and does not NEED a 12V electrical system. 12V is nice, but not absolutely necessary.
