Re: Cleaning Carb
Posted by soybeanjoe on June 14, 2010 at 05:40:16 from (66.213.171.108):
In Reply to: Cleaning Carb posted by Rodger Wells on June 14, 2010 at 04:48:04:
Carb spray cleaner is ok if the carb isn't too dirty but I prefer using the "soak" treatment. Most automotive stores sell a 1 gal pail of carb dip cleaner with a small wire basket for soaking. Take the carb completely apart & put all the pieces , or at least what you aregoing to reuse, in the basket then let them soak in the cleaner for 24 hrs.
When I remove the parts from the cleaner I use a spray cleaner & air to get any crud off the surface & out of any passageways. After assembly I like to spray the outer surface of the carb with a spray laquer to seal it.
