Re: H wont come up to full RPM.
Posted by Allan In NE on June 14, 2010 at 06:11:45 from (148.66.88.254):
In Reply to: H wont come up to full RPM. posted by Fuller's Farmall on June 13, 2010 at 18:53:34:
The first thing to check on these old gals is the ignition timing.
As the points wear, they will in turn directly "slow timing", which really drags 'em down.
On a '44, I imagine you have a mag, and therefore set to .013". If your tractor is equipped with a distributor, set the points .018-.020".
Then, feel out and set that timing to where the engine breaths free. Oh, and carb adjustments should always be done as the last step.
This should make for far better starting also.
Allan
