3 Amps rating should suffice for the alternators required initial excitation current and 100 volts withstand rating is plenty so YES it should work okay, rememember its polarity sensitive so for Neg ground its Cathode band should be towards the alternator.
NOTE instead of a diode one can use EITHER a 10 ohm 10 watt resistor (no worry about polarity) as it also prevents the run on problem PLUS provides some degree of current limiting safety ORRRRRRRRRRR instead one can use a small incandescent idiot light charge indicator to be on when shes NOT charging but off when she is ORRRRRRRRRRRRR use the idiot light in paralell with the current limiting safety resistor so she can still charge should the idiot light burn out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
