Re: 1929 McCormick Deering 10-20 stuck engine
Posted by James Williams on June 14, 2010 at 10:41:25 from (65.73.12.207):
In Reply to: 1929 McCormick Deering 10-20 stuck engine posted by Ct Hay Farmer on June 13, 2010 at 19:10:43:
The 10-20 is probally the easiest motors to unlock.Ive done several of them.Remove your head your clutch,and the oil pan.If the pistons are half way down fill the cylinders with deisel fuel and a little gas and lght them.Let them burn slow,do this several times.There are 2 holes in your fly wheel put 2 peices of pipe in them and use a diging bar to force the motor in either direction.I have also removed the rod caps,cut a 3/4 peice of steel a little smaller than the cylinder,lay it on top of the piston and hit it hard with a very heavy sledge hammer,protect the cylinder walls with a peice of plastic container.The pistons has to be taken out through the bottom becaues the rod ends are larger than the cylinders
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
