Re: yellow Farmall M ?
Posted by mkirsch on June 14, 2010 at 13:30:10 from (64.80.108.57):
In Reply to: yellow Farmall M ? posted by Kevin Davison on June 14, 2010 at 10:25:51:
Kevin Davison said: (quoted from post at 10:25:51 06/14/10) Any idea where I can find the serial # ? The tag is missing on the clutch houseing.
If that tag is missing, you're pretty much out of luck.
The exact serial number for that tractor was only stamped on the serial tag. There is an engine serial number, which might be close, or if the engine has been swapped out, may be way off.
