Re: MTA Split problem
Posted by 504 on June 14, 2010 at 20:16:10 from (216.145.144.254):
In Reply to: MTA Split problem posted by Ruegers on June 14, 2010 at 19:50:12:
Unhook the coil wire, put the transmission in neutral, make sure everything is blocked, bump the starter once or twice and if you have the clutch plate installed right it will fall together. I also use a couple of long bolts with the heads cut off for guides. The clutch plate must be centered to the pilot bearing or it will never go together. Good Luck.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
