Re: 656 IH
Posted by The tractor vet on June 14, 2010 at 20:45:17 from (76.212.236.89):
In Reply to: 656 IH posted by Chris Doe on June 14, 2010 at 16:56:56:
Ya got her out of time pull it back apart line up the little lines in the timing window of the pump then look in the end of the pump and look for the DOT then look at the shaft and there will be a DOT on the end of it and then ya make the two DOTs line up , just becareful not to roll the cup seal when your going together or you will have fuel in the pan and asking how to fix that .
