Re: Farmall C wiring pic's
Posted by mkirsch on June 15, 2010 at 05:11:26 from (64.80.108.55):
In Reply to: Farmall C wiring pic's posted by dougct on June 14, 2010 at 15:44:51:
Did you install a REGULATOR or a CUTOUT?
If you have the 4-position switch, you should have installed the CUTOUT.
If you have the 3-position switch, you should have installed the REGULATOR.
You can install a regulator with the 4-position switch but the wiring will be different.
