Posted by sflem849 on June 15, 2010 at 07:13:07 from (69.197.84.192):
In Reply to: MTA Split problem posted by couv on June 14, 2010 at 19:50:12:
For those who haven't been back and forth
The tractor vet said: (quoted from post at 20:37:12 06/14/10) Good grief , Pull it back apart and remove the pressure plate and place it on the floor and use your hgeel and push one release lever down at a time and lock the lever down with a 1/4 inch nut then do the next and then the next this hold the pressure plate in the release possession . Next hang the pressure plate on the PTo input shaft then hang the clutch disc in the transmission shaft and slid it together , Then remove the inspection cover off the bottom of the bell housing and work up thru the bottom and bolt the pressure plate to the flywheel . This ain't rocket science it a flippen tractor. Oh and it really helps if the bell housing is clean or you will have grease clean up to your arm pit.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
