Re: Update on the C wiring
Posted by Janicholson on June 15, 2010 at 17:16:35 from (64.61.211.85):
In Reply to: Update on the C wiring posted by dougct on June 15, 2010 at 15:26:59:
The lights may have a short in them. First remove all the bulbs and see if it still discharges. If so the wires need to be traced to find the fault to ground. On dim the switch will get warm. but not hot. There is a resistor on the back for Dim lights. In the L charge position the other resistor is heating to reduce the field current. Also warm. If it is getting hot, it may be the place where there is a short. Jim
