Re: Farmall 350 RC Gas Wiring diagram
Posted by Janicholson on June 15, 2010 at 17:50:23 from (64.61.211.85):
In Reply to: Farmall 350 RC Gas Wiring diagram posted by Dale Allen on June 15, 2010 at 15:04:11:
The Relay on the starter has two small, and two large terminals. The large terminal near the S (of the two small ones)terminal is to the battery.
The S terminal itself goes to the start terminal of the push button, (or from the S terminal of a key switch)
The "I" terminal goes to the coil side of a ballast resistor (if equipped) or is ignored if a 12v no resistor coil is used.
The other large terminal goes to a metal bracket hooked to the starter motor stud. The remaining wiring questions should be answered by the attached diagrams. Jim
