No, only 1 wire goes to the F on generator and with your regulator it would be from F on regulator. The regulator is automatic so we give it priority.
You could either completley remove the gray wire from the L on regulator, or disconnect the short red ended wire which now connects on the ammeter with the green wire and connect this red wire to the L terminal. This is the wire that feeds the light circuit.
Then the regulator will automatically control generator output and you would use the switch for lights only.
The switch had the light section and the Hi-Lo generator section. They switched together but were separate systems so there is no problem switching just the lights with the switch.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
