Re: Farmall 450 Power Steering
Posted by pete 23 on June 16, 2010 at 11:18:25 from (173.87.0.80):
In Reply to: Farmall 450 Power Steering posted by Alan Sperfslage on June 16, 2010 at 09:01:57:
My question to you is , if you hold an aux valve lever on demand will it steer better. If it does that indicates that your flow divider valve is worn and leaking past the lands, common problem. If it does not steer any better it would indicate a leaking steering unit, or relief valve, or weak pump. The flow divider spool is available at CaseIH, and easy access to replace. If new spool doesn't help, then valve body is worn also and it gets really expensive to have them rebuilt.
