Re: Farmall M with no spark (help)
Posted by RustyFarmall on June 16, 2010 at 13:08:29 from (209.152.78.140):
In Reply to: Farmall M with no spark (help) posted by Farmall M Beginner on June 16, 2010 at 12:22:47:
You may need to replace the magneto coil also, which is a fairly straight forward "do-it-yourself" job, but getting the iron shaft out of the old coil and into the new coil is a bit of a trick, or so I've been told. Digging any deeper into the mag might require some expertise and knowledge to put it back together.
