Re: Farmall M with no spark (help)
Posted by Haas on June 16, 2010 at 16:52:31 from (75.216.125.25):
In Reply to: Re: Farmall M with no spark (help) posted by Farmall M Beginner on June 16, 2010 at 14:46:15:
Yes, true, but it will cost just as much as getting your magneto repaired. That is unless you do the jury rig and add an external battery ignition coil and use the mag distributor. I don't like that and I've converted a couple back to mags that were done that way.
