Re: Super C starting Problems
Posted by El Toro on June 16, 2010 at 17:10:06 from (74.103.74.58):
In Reply to: Super C starting Problems posted by DFZ on June 16, 2010 at 15:58:46:
You probably need to have your battery load tested to see if it has a weak cell. Put the battery on a charger overnight and use a hydrometer to check the specific gravity in each cell and compare readings. Should be in the 1.260 range. If you have another battery that's fully charged you could swap battery's. I think your battery voltage is too low for the tractor's ignition. Hal
