If your meter has ohms scale--RX1--unhook the neg cable from the battery & measure resistance between neg cable & ground [tractor frame]. What resistance is present? If resistance is less than 100 ohms, start unhooking wires 1 at a time from the ammeter until the reading is near infinity [high resistance]. Bear in mind that the starter switch may be causing some trouble here, so check that out also. Look for bare or garfed wires/ insulation bad. Could also disconnect wires 1 at a time from the regulator to isolate a problem there.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
