Posted by RustyFarmall on June 17, 2010 at 05:50:39 from (209.152.78.140):
In Reply to: w6 rear axle spline posted by farmall paul on June 17, 2010 at 01:26:01:
Replacing the wheel would be the correct way to fix it, but if there is no replacement wheel then that is not a remedy. Probably the next best fix is to weld up the worn areas and then either grind or hand file the welds so the wheel will fit. It will be time consuming.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
