Posted by GordoSD on June 17, 2010 at 06:32:10 from (216.106.248.15):
In Reply to: '53 Super H brakes posted by Tom Bond on June 16, 2010 at 17:57:10:
I've rebuilt disc brakes on 5 Farmalls. After the first two and still some barely adequate performance from the all new systems I Tried the following. Grind the tractor surface clean with 40 grit flap wheel. Use lathe to turn inner surface of the cover drum. Not too smooth here. Machine .100 off the edge of the cover drum either by planing or milling. This last step allows for all the wear over the years of the two steel surfaces that the discs work against. When you do this you can skid the rear tires on a blacktop road!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
