The heavy assembly with the two pulleys bolts under the back of the tractor to the final drive housings. There are three bolts each side that attach to the front mounting holes of the final drives, not the rear mounting holes where the drawbar attaches. The pulleys are on the back side. If there are stud bolts in the mounting holes on the final drive you will have to remove those and use 3/4 inch bolts to attach the pulley frame. Are you sure you have the correct manual. I mounted mine using the manual and did the same to a Cub for a friend and did not have any trouble.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
