Re: IH766 hydraulics
Posted by The tractor vet on June 17, 2010 at 19:45:08 from (76.212.236.89):
In Reply to: IH766 hydraulics posted by wayne766 on June 17, 2010 at 17:49:34:
You are dropping pressure on the MCV So you may be in need of a new MCV pump or your flow divider is sticking The pump needs to be flow rated with a hyd. flow rater to see if it is putting out the correct gallons per min and at proper pressure . This needs to be done by someone that has a flow rater and the knowledge on how to preform the test . If it is a sticking flow control valve then here again it is best to let someone who knows what he is doing .
