Posted by Brownie 450 on June 18, 2010 at 05:02:20 from (66.43.241.95):
In Reply to: alternator update posted by karl f on June 17, 2010 at 12:57:55:
Have you tested the diode trio? Sounds like JS might be right with a new reg. If 1 or 2 sections of the trio are bad/ open, you won't get full field voltage/ current. Last year, the 1460 had 2 sections open on the trio--looked like the metal leads got melted. Use an analog [preferred] meter to test the diode trio. RX1 on the resistance scale with 1 lead on the single terminal--other lead to each of the other terminals. Readings should be either infinity [high ohms] or ~ 35 ohms. Now switch leads & readings should be reverse of previous test. If any of the 3 sections is open, replace the trio.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
