Re: H hydraulic cylinders
Posted by Janicholson on June 18, 2010 at 06:08:10 from (199.17.6.222):
In Reply to: H hydraulic cylinders posted by Farmallb on June 17, 2010 at 17:01:05:
There several
All (of the ones i think you are discussing) are single acting and have a ram that is contained in a sleeve on the business end, with a single mounting tab with hole on the cylinder end.
The two most commonare distinguished by either having three tie bolts/rods on the outside, or four. The four bolt cylinders (If I remember correctly) are about 1/4" larger bore than the 3 bolt, and will stand more pressure. When the pumps were set to 650 the three bolt were supplied, I think the four bolt were made when the systems Liftall belly pumps were set to 800psi. At least it is what I remember. Jim
