Re: Just Bought 1964 Farmall 706, needs some things
Posted by mkirsch on June 18, 2010 at 06:24:19 from (216.43.0.10):
In Reply to: Just Bought 1964 Farmall 706, needs some things posted by Marie in California on June 17, 2010 at 15:35:28:
The gears are NOT "worn down to nubbins."
Your problem is that the springs on the shift detents are broken. There's a cam mechanism in the transmission that holds the tractor in gear, which uses a spring to hold the gear shift in place. If the gear lever "floats" and doesn't "snap" into place, that is your problem.
This requires removing the platform and pulling the range cover, which is located about where you keep your feet. It's not a huge job but if you're not mechanically inclined, you may want to seek local assistance.
