Re: Re: Wiring diagram for H
Posted by Finn in MN on June 01, 2000 at 05:53:35 from (216.17.30.1):
In Reply to: Re: Wiring diagram for H posted by The Red on May 31, 2000 at 15:23:36:
The Red, Thanks for the diagram. I also found a diagram in the archives under "packrats did my wiring job" for a super H. My voltage regulator is mounted on the chassis, not on the generator. My H also has a coil and distributor, which I do not see in the picture. I can't get to it until Saturday, so I don't have any other questions at this time. If you have any other suggestions, my ears are open. It looks easy in the picture. Thanks for the help.
Post A Followup
: Re: Re: Re: Wiring diagram for H
