Most Fuel level gauges use a resistor in the sending unit to send current to the meter. the meter then converts this to needle movement. (usually using a bimetal heat sensitive bar with a heater wire wrapped around it, or by an electro magnet movement sensitive to current. In most applications, the gauge gets power through a IVR (instrument Voltage Regulator) or directly from the ignition terminal on the key switch. From the gauge the current flows to the tank sending unit, and from the variable resistor in that to ground. It may not make a difference which post is connected! I hope this helps some. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
