Re: A Farmall lookn4 -hand crank- also
Posted by Jim Broughton on June 18, 2010 at 20:07:28 from (207.69.137.20):
In Reply to: A Farmall lookn4 -hand crank- also posted by tractormandiggerdozer on June 18, 2010 at 19:28:59:
Sounds like a governor problem to me !!
Check it out !!
I made my own crank for my IH Cub, including "release spring" so I don't get hurt... but I wouldn't try to hand crank your tractor until you have the timing and engine RPM under control, otherwise you could get HURT !!
Jim B.
