Re: A Farmall lookn4 -hand crank- also
Posted by gene bender on June 19, 2010 at 03:45:23 from (67.55.226.132):
In Reply to: A Farmall lookn4 -hand crank- also posted by tractormandiggerdozer on June 18, 2010 at 19:28:59:
You have a gov problem check the linkage as it is bound up somewhere, You cant retard the timing by turning the mag. Dont change the rotor or you wont be able to start it and just cause more problems. The linkage where it goes to the carb is probably frozen and wont let the linkage move from the gov. Unhook the linkage on both ends and get it to move free with now binding
